We designed the Baldrick footprint to be compatible with common smart receiver mounts — but our community has gone further.
That hasn't stopped our incredible friends and customers from building their own mounts, and with their permission, some of them are here to download.
These mounts have been designed and shared by our amazing community members. Thank you to all the contributors!
SmallSmall board mounts
Mounts sized for Baldrick Pixel Board S and other small-form-factor boards.
IKEA SKÅDIS Mount
Designed by Ianson Design
A clean, low-profile mount that attaches a Baldrick Pixel Board S to an IKEA SKÅDIS pegboard — ideal for desks, workshops, and maker stations.
MediumMedium board mounts
Mounts for medium Baldrick boards — the same footprint as many common smart receivers.
IKEA SKÅDIS Mount
A clean, low-profile mount that attaches a medium Baldrick board to an IKEA SKÅDIS pegboard — ideal for desks, workshops, and maker stations.
Original Baldrick Mount
Designed by Greg Macaree
This mount has breakout clips and is designed to fit on a Meanwell RS320 power supply.
Pi + Buck Converter Mount
Designed by Stephen Parberry
This mount allows the addition of a Raspberry Pi and Buck Converter to the power supply unit.
Double Stack Meanwell Mounts
Designed by Matt Connolly
Hi all, I needed to stack 2 RSP-320's having each one power a side of the Baldrick8 so I've designed these rails with a bend in them so you can still use the standard RSP Baldrick mounting plate.
HP 750W Server PSU Gridfinity Mount
Designed by Keith
A Gridfinity cradle and mount for a Baldrick8 and an HP 750W Common Slot server PSU (DPS-750RB / HSTNS-PL18). The board sits on a 3×2 mount beside the PSU, and both lock into a 3×5 baseplate so the pair stays put but lifts out together. Print the cradles in PETG — the case gets warm under load.
LargeLarge board mounts
Mounts for Baldrick17 and other large-form-factor boards.
IKEA SKÅDIS Mount
A clean, low-profile mount that attaches a Baldrick17 (Pixel Board L) to an IKEA SKÅDIS pegboard — ideal for desks, workshops, and maker stations.
