BaldrickInput8
BaldrickInput8 Web Interface
Complete configuration and control guide
The BaldrickInput8 includes a powerful web-based configuration interface that allows you to set up and control your board from any web browser. This comprehensive guide covers every aspect of the web interface.
Quick Navigation
Access: Connect to your network and navigate to the BaldrickInput8's IP address in your web browser. You can find the IP address in your router's DHCP client list or by using network scanning tools.
The Stats board gives you a heads up as to what's going on with your controller.
The BaldrickInput8 is pretty new in the world of controllers and we've got a LOT of features left to add, this will let you know your current version and if there is a version to upgrade to.
The BaldrickInput8 comes with eight Turniput ports to attach external triggers (buttons, beam breaks, motion sensors) that can be configured when triggered to do a multitude of tasks.
Control FPP (Falcon Pi Player) instances, change volume, play songs/playlists, or call FPP API directly.
Quickly enable any test mode at a specific brightness for quick prop testing.
Turn on/off BaldrickSwitchy ports for specific durations (bubble machines, snow machines, etc.).
Activate preset commands on your BaldrickDMX for moving heads, effects, etc.
Call web APIs from simple triggers - perfect for custom integrations.
Sometimes you set an input to do something and think "oh actually no, that's not what I want."
Note: The main difference between this and the Button input on the Baldrick8 is the addition of Lamp controls.
Note: WiFi on the Input8 is currently in testing and will be released soon.
The default hostname is baldrickboard (hence baldrickboard.local). If you have one BaldrickInput8 then it's completely fine to keep this as it is, however if like us you want to collect a few of them, then we'd recommend you change this to something like frontgardenor upstairsroof
The default option is DHCP (which is Dynamic Host Configuration Protocol but you don't need to know that) which basically means your router or computer gives the board an I.P. address. This is great for initial setup but when you want to run a show it's best to switch it to STATIC, that's where your controller tells the router / computer "This is my IP".
DNS wise, typically, your default gateway is your router IP, and that more often than not, can provide your network with DNS. However, some people like to use "outside 3rd parties" DNS like google or cloudflares DNS. If you don't know about this, its probably best just to stick to DHCP.
The Baldrick family of boards have developed with ease of use as one of the core principles, this lead the creation of 'The Turnip Network'.
It's what those people in business suits call 'synergy'!
Advanced settings provide additional configuration options for power users and complex installations.
Coming Soon
Advanced settings documentation will be added as new features are developed and released.
