BaldrickSignals Manual
Last updated 21 Sep 2026
Getting Started with BaldrickSignals
We’re still working on this getting started guide. In the meantime, check out our web interface documentation for some configuration details. By adding /csv to the IP Address of your signals board, you’ll get a lovely CSV of all the historical data we’ve got. We’ve got a Google Sheet that you can use to visualise this data and translate it.
How to Use the Template
Access the Template
Click the link above to open the Google Sheets template in your browser.
Make a Copy
Go to File → Make a copy to create your own version of the spreadsheet.
Export Your Data
Navigate to your BaldrickSignals IP address with
/csvappended (e.g.,http://192.168.1.100/csv) and copy the CSV data. -
Import Your Data
Delete the information in the first two columns of the template and paste your CSV data.
View Your Graphs
The Graph page will now show you a pretty graph of your signals data.
Eventually this should update automatically but we are not there yet!
<nav>
<button class="manual-tab active" type="button" data-action="click->tabs#switch" data-tab="v1-1">BaldrickSignals v1.1</button>
<button class="manual-tab" type="button" data-action="click->tabs#switch" data-tab="v1-0">BaldrickSignals v1.0</button>
</nav>
<div class="tab-panel" data-tab="v1-1">
<div class="figure">
<div class="fimg">
<img src="baldricksignals/breakdown11.png" alt="BaldrickSignals v1.1 Board Overview" class="doc-img">
</div>
</div>
<ul>
<li><strong>1. Power Jack —</strong> You can put 5v-48v through a barrel connector (centre positive) and we use 5.5x2.1mm barrel jacks.</li>
<li><strong>2. 2 Pin Pheonix Connector —</strong> You can put 5v-48v through this connector.</li>
<li><strong>3. CR2032 Coin cell clip —</strong> Using this will allow the BaldrickSignals to keep the time even when the board is disconnected from the network (this will not power the board). Your vendor will probably not supply this so make sure you've got one.</li>
<li><strong>4. Wireless Chip —</strong> The BaldrickSignals uses wifi to detect other devices, you'll need an <a href="/faq#antennas">antenna</a>.</li>
<li><strong>5. 100mb Ethernet Port —</strong> You can use this to connect to your show network.</li>
<li><strong>6. QR Code —</strong> An easy to scan QR code which will take you to these docs for easy troubleshooting.</li>
<li><strong>7. Oh No button —</strong> Use this to reset the board by holding for 5 seconds when the board is booting.</li>
</ul>
</div>
<div class="tab-panel hidden" data-tab="v1-0">
<div class="fimg">
<img src="baldricksignals/breakdown.png" alt="BaldrickSignals v1.0 Board Overview" class="doc-img">
</div>
</div>
<ol>
<li><strong>Power Jack —</strong> Can take 5v to 24v (each side can take different voltages) and will automatically step down to power the components, no jumpers needed. <strong>Whatever voltage you used here is also used to power the lamp</strong>.</li>
<li><strong>CR2032 Coin cell clip —</strong> Using this will allow the BaldrickSignals to keep the time even when the board is disconnected from the network (this will not power the board). Your vendor will probably not supply this so make sure you've got one.</li>
<li><strong>Wireless Chip —</strong> The BaldrickSignals uses wifi to detect other devices, you'll need an <a href="/faq#antennas">antenna</a>.</li>
<li><strong>100mb Ethernet Port —</strong> You can use this to connect to your show network.</li>
<li><strong>QR Code —</strong> An easy to scan QR code which will take you to these docs for easy troubleshooting.</li>
<li><strong>Oh No button —</strong> Use this to reset the board by holding for 5 seconds when the board is booting.</li>
</ol>
</div>
The web interface has been designed to be as simple as possible
This will let you know your current version and if there is a version to upgrade to.
Crowd Monitoring
Crowd Detection
Now we get to the good stuff. Every 30 seconds we will poll the universe (or at least as far as the antenna will detect).
Network Configuration
The default hostname is baldrickboard (hence baldrickboard.local). If you have one Baldrick8 then it’s completely fine to keep this as it is, however if like us you want to collect a few of them, then we’d recommend you change this to something like frontgarden or upstairsroof
The Baldrick Boards will keep an eye out on the network for other Baldricks and let you know how they are doing (this is helpful as we don’t put an LCD screen on the board).
You can directly jump to their control panel from this interface and when they appear in this list, more board functionality will become available.
Enable Beta Updates
Sometimes we put updates out that aren’t quite ready for prime time (or in the case of a Seasonal Freeze, it’s an update which isn’t critical).
Permanent Device Offset
At this current state of development and to comply with all data protection and GDPR laws, Signals gives you a static number of the devices detected. In many cases there will be devices detected which are present all the time (such as your phone). You can offset this by putting a number in this box (the number will never go below zero!).
Crowd Multiplier
Depending on your audience type, you might find that your audience isn’t quite representative of the number of mobile devices detected (if you have a lot of young children visiting with parents you might find it vastly under counts). You can offset this by putting a multiplier in this box (the base number minus the offset will be multiplied by this amount).
