BaldrickSignalsWhere to Buy
Signal Controller
BaldrickSignals Web Interface
Complete configuration and control guide
The web interface has been designed to be as simple as possible
BaldrickSignals Web Interface Stats
The Stats board gives you a heads up as to what's going on with your controller.
This will let you know your current version and if there is a version to upgrade to.
Crowd Monitoring
Crowd Detection
BaldrickCrowd Web Interface Crowd
Now we get to the good stuff. Every 30 seconds we will poll the universe (or at least as far as the antenna will detect).
Network Configuration
BaldrickSignals Web Interface Network
The default hostname is baldrickboard (hence baldrickboard.local). If you have one Baldrick8 then it's completely fine to keep this as it is, however if like us you want to collect a few of them, then we'd recommend you change this to something like frontgardenor upstairsroof
The default option is DHCP (which is Dynamic Host Configuration Protocol but you don't need to know that) which basically means your router or computer gives the board an I.P. address. This is great for initial setup but when you want to run a show it's best to switch it to STATIC, that's where your controller tells the router / computer "This is my IP".
DNS wise, typically, your default gateway is your router IP, and that more often than not, can provide your network with DNS. However, some people like to use "outside 3rd parties" DNS like google or cloudflares DNS. If you don't know about this, its probably best just to stick to DHCP.
BaldrickSignals Web Interface Friends
The Baldrick Boards will keep an eye out on the network for other Baldricks and let you know how they are doing (this is helpful as we don't put an LCD screen on the board).
You can directly jump to their control panel from this interface and when they appear in this list, more board functionality will become available.
Enable Beta Updates
Sometimes we put updates out that aren't quite ready for prime time (or in the case of a Seasonal Freeze, it's an update which isn't critical).
Permanent Device Offset
At this current state of development and to comply with all data protection and GDPR laws, Signals gives you a static number of the devices detected. In many cases there will be devices detected which are present all the time (such as your phone). You can offset this by putting a number in this box (the number will never go below zero!).
Crowd Multiplier
Depending on your audience type, you might find that your audience isn't quite representative of the number of mobile devices detected (if you have a lot of young children visiting with parents you might find it vastly under counts). You can offset this by putting a multiplier in this box (the base number minus the offset will be multiplied by this amount).
