BaldrickSwitchy Web Interface
The web interface has been designed to be as simple as possible
Quick Navigation
Access: When you first power on your BaldrickSwitchy, it creates a WiFi access point named "BaldrickSwitchy-XXXX". Connect to this network (no password required) and navigate to 192.168.4.1 in your web browser.
The Stats board gives you a heads up as to what's going on with your controller.
This lets you know what FPS (Frames Per Second) the controller is currently outputting (Why would I need this for a relay board you may ask, and we will let you keep guessing)
Let's you know what version firmware your BaldrickSwitchy is currently running.
Tells you the current IP address of the Baldrick Switchy.
Test mode is one of the most important features of the Baldrick Board. If it's two hours before switch on and something is going wrong, YOU NEED CLEAR INFORMATION QUICKLY.
Presets
At the moment we only have one preset, Alternate Relay which alternates between on and off every second, but you can see we've made that Presets box into a dropdown as we know we'll think of some later.
Apply to
Select your port (or all ports) you'd like the effect applied to.
Relay Configuration
Manual Relay Setup
Whilst we expect much of the configuration to be pushed from xLights, you can directly add your devices to the BaldrickSwitchy from this section.
It's a simple interface with only a name and a trigger threshold.
The default hostname is baldrickswitchy (hence baldrickswitchy.local). If you have one BaldrickSwitchy then it's completely fine to keep this as it is, however if like us you want to collect a few of them, then we'd recommend you change this to something like frontgardenor upstairsroof
The default option is DHCP (which is Dynamic Host Configuration Protocol but you don't need to know that) which basically means your router or computer gives the board an I.P. address. This is great for initial setup but when you want to run a show it's best to switch it to STATIC, that's where your controller tells the router / computer "This is my IP".
DNS wise, typically, your default gateway is your router IP, and that more often than not, can provide your network with DNS. However, some people like to use "outside 3rd parties" DNS like google or cloudflares DNS. If you don't know about this, its probably best just to stick to DHCP.
The Baldrick Boards will keep an eye out on the network for other Baldricks and let you know how they are doing (this is helpful as we don't put an LCD screen on the board).
You can directly jump to their control panel from this interface and when they appear in this list, more board functionality will become available.
